Run-flat tires for armored car
ParaShootist
Scenic E. Oklahoma
As I've considered acquiring a wheeled AFV, it struck me that RF tires would be a pretty cool thing. I've learned that Ferrets were originally equipped with RF tires and inserts. However, a number I've looked at seem to have been refitted with newer ND tread non-RF tires (in one case the inserts were not put back in :confused:). Are there many/any real options for RFs for these old armored cars other than OLD original rubber or NOS? I figure original-type Dunlop RFs are long out of production - my limited webfu didn't turn up any this side of the pond and nothing 'new.' In the case of the Ferret, the U.S. type ND tread certainly doesn't "look" very authentic. Looks are one thing, tires suitable for the vehicle are another.
I am just curious what the options are? Is it anything that the MV community has much of an opinion on - like impact to value?
B3.3T
109
SW Ohio
The standard issue Dunlop tires on Ferrets serve as run-flats. In fact, a delated Dunlop- which I have experienced- makes the Ferret simply harder to steer and far from flat. These are tough military-grade tires. No real need for anything more.
ParaShootist
Scenic E. Oklahoma
Where oh where have the Dunlops gone
The standard issue Dunlop tires on Ferrets serve as run-flats. In fact, a deflated Dunlop- which I have experienced- makes the Ferret simply harder to steer and far from flat. These are tough military-grade tires. No real need for anything more.
Roger that. Thank you B3 – I was hoping for your perspective. However, I guess I wasn’t all that clear in framing my query. I'm not wanting something else, but . . .
What if the original Dunlops are missing? (like, "Look at that silly Ferret wearing some other type of tires."):shock:
A bit of searching the web didn’t turn up any of those fine old military tires for sale, and I don’t just want to assume they’re reasonably available.
Are new (or at least decent condition) 9.00x16 Dunlop RFs reasonably available for sale?
If not, is there a reasonable, comparable, military-grade RF alternative?
Maybe the easy answer is to just NOT consider buying a Ferret that’s not wearing original Dunlop RFs.
That would rule out the last two otherwise nice condition Mk2/3s I've looked at.
M813 said I'd need to be patient.
