How pleased are you with the interior sound reduction?View attachment 450031
Updated the interior
Carpet kit from LMC
Speaker box's homemade
And a dynamat + speaker box carpet head liner.
Cover the threaded holes with small pieces of masking tape. Didn't need a respirator. I did the prep outside in the driveway. The Xylene wasn't bad at all, I didn't even smell it. The Herculiner kit comes with a scotch bright pad to scuff up the paint. I used a wire wheel on anything loose. Thanks for the comments.Process for Herculiner: what did you fill the holes with? Also, I assume that you have to use a respirator. Correct? What type of sandpaper?
Looks like a professional job!
www.aspwholesale.com has the 24v kit for both the direct drive and gear reduction. You need to call them and specify 24v.Pulled the starter...24V....and the drive is worn out...that would explain why the shop couldnt start it....SO looked allover the SS forum and no vendor linked has the full rebuild kit in stock with the drive....
What do i do now!!! Im in Canada so the access to used extras is like hens teeth. Pulling apart starter as I type!!!
I suggest the same. MY last TV bracket was red like yours. Guessing an 82 version. Wrapped up obtaining a set of ford rims as they are wider than the stock CUCV selection. My 255/85R16 tires are on the way. Looks like I'll have fresh rubber for the rally.Went out for my weekly exercise at the local pull-a-part
This followed me home
View attachment 450542View attachment 450543
Diesel 700r4, with torque converter, flywheel and the illusive TV bracket. All for under a C-note
Guys get out and get some exercise instead of typing on the keyboard.![]()
http://www.aspwholesale.com/index.php?act=viewProd&productId=5977 - gear reduction
http://www.aspwholesale.com/index.php?act=viewProd&productId=6174 - direct drive **** just noticed that they are out of stock, you might call as the webpage may not be up todate.
