Warthog
245
OKC, OK
That's great news!!! Run her hard to cleanout the cobwebs.
Next we will work on the a/c
Lild
Nashville,nc
New plugs, fuel filter, fuel pump, ip, starter w/bolts, cleaned all the post & terminals for the electrical. Working on getting new crankshaft pulley, going to get the engine bay cleaned up this weekend, then onto getting the interior cleaned up & painted, a radio,then body & paint work.
1,827
Pulled the transfer case out of the ambulance last Friday for a rebuild. Lots of axial play in the main shaft when I pulled it. Low and behold the case is shot. Tossed it in the can and rebuilt one of my backups. Got it hung and bolted in today. Will tidy things up in the AM.
MilChevyguy, post up when you list that box. I forget whats in there but I'm always looking for odds and ends.
I_Publius
Prosper, TX
Gave mine a good vacuum today. It was full of rat droppings after having sat for ten years in a West Texas field, plus one remainder of a rat. Nice. ;)
Got her inspected yesterday and then the rear view mirror fell off an hour later. It had disintegrated, so I got a new one and installed her this afternoon.
Finally, the huge purchase...a brand new set of tires. Ugg....but, it's too hot here in Texas to drive around on bad tires, safely.
Oh...and brought her home last night. My wife hasn't thrown me out out, yet, and my young kids love it. Great weekend. :)
I_Publius
Prosper, TX
Process for Herculiner: what did you fill the holes with? Also, I assume that you have to use a respirator. Correct? What type of sandpaper?
Looks like a professional job!
665
Madison Alabama
Cover the threaded holes with small pieces of masking tape. Didn't need a respirator. I did the prep outside in the driveway. The Xylene wasn't bad at all, I didn't even smell it. The Herculiner kit comes with a scotch bright pad to scuff up the paint. I used a wire wheel on anything loose. Thanks for the comments.
MilChevyguy
Toronto Ontario Canada
Pulled the starter...24V....and the drive is worn out...that would explain why the shop couldnt start it....SO looked allover the SS forum and no vendor linked has the full rebuild kit in stock with the drive....
What do i do now!!! Im in Canada so the access to used extras is like hens teeth. Pulling apart starter as I type!!!
I_Publius
Prosper, TX
I would suggest mailing it down here to Texas. I have a local guy who could rebuild that starter in one day that we could ship it back to you.
Might be a bit expensive on the shipping, however.
I hope you can get something figured out locally. :)
Warthog
245
OKC, OK
Went out for my weekly exercise at the local pull-a-part
This followed me home
Diesel 700r4, with torque converter, flywheel and the illusive TV bracket. All for under a C-note
Guys get out and get some exercise instead of typing on the keyboard. :mrgreen:
Warthog
245
OKC, OK
www.aspwholesale.com has the 24v kit for both the direct drive and gear reduction. You need to call them and specify 24v.
http://www.aspwholesale.com/index.php?act=viewProd&productId=5977 - gear reduction
http://www.aspwholesale.com/index.php?act=viewProd&productId=6174 - direct drive **** just noticed that they are out of stock, you might call as the webpage may not be up todate.
1,827
View attachment 450542View attachment 450543
I suggest the same. MY last TV bracket was red like yours. Guessing an 82 version. Wrapped up obtaining a set of ford rims as they are wider than the stock CUCV selection. My 255/85R16 tires are on the way. Looks like I'll have fresh rubber for the rally.
Warthog
245
OKC, OK
Correct on the 1982. I'm going to swapout the case for a 1989 4x4 version.
MilChevyguy
Thanks Warthog...that is the first place I hit after searching all the leads and links on the forum!!!
Even fleabay and Gooble to see if any other vendors will mail to Canada.
So far no luck but will call ASP on Monday...crossing fingers...I need to get my ride rolling before the snow flies again (really just want it out of the garage again)
Took the starter apart and for sure the drive is worn REALLY bad....and the flywheel is looking a bit shabby too...(hint hint...someone just got one from a Pull-a-part:?)
Warthog
245
OKC, OK
What starter do you have. The fat direct drive or the skinny gear reduction?
MilChevyguy
Its the big fat direct drive....original one in this truck by the looks of everything...still 24V with the proper GM support bracket.
Seems it was just wear from use, it was fine till I had the desiel leak make everything slippery and that is when the starter started to slip and grind.
