cucv fuel pump rod trouble
sante
albany,ny
Help.
I tried to replace my fuel pump, got old off ok, but can't keep cam rod up to install new one. Tried hacksaw blade trick, failed tried 4 different greases, failed . Told about a bolt that u could remove and put longer one in, but there isn't one ( can't find it there is, checked a cucv blazer none there) I don't know what else to do. Any ideas? I tried for 8 hrs and no luck
Thanks
Sante
doghead
4 Star General /Moderator
1,168
Tip it on it's side?
Recovry4x4
LLM/Member 785
1,814
GA Mountains
Bump the engine over a bit. Lobe is likely on the down stroke. GAA looks like and has a similar consistency of peanut butter. Works for me.
Hasdrubal
Vancouver BC
I've done many fuel pump re & re's. A dab of regular multi-purpose grease on the end has never failed to retain the rod in position. You must be doing something wrong. First make sure it goes all the way up with your finger, as every one else has said. Put the grease on the end going in, I just put the end in the grease container so that there about 3/4 inch covering the rod and the grease blob is about a 1/4 inch wider in diameter. That's it, unless the laws of physics has been altered in your locale...it will stay up.
