Gear oil question
eeyore357
B'Ham AL
Is there a gear oil out there that can be used in the diffs, trans, and transfer safely? I have been reading and reading and I think my head is going to explode. I am planning a complete fluid change this weekend.
Flyingvan911
158
Kansas City, MO
It seems SAE 50 is good. I am using NAPA GL-5 80W90 with no issues. Other guys use GL-1. Aswayze said when he switched from GL-5 to 50 weight his tranny seemed to shift a little smoother. I think changing it regularly and keeping everything lubed is more important than which one of the three you use.
eeyore357
B'Ham AL
Is the NAPA gear oil you're using yellow metal safe? I was going to go with Shell Spirax A 80W-90 but I can't find it anywhere local.
doghead
4 Star General /Moderator
1,191
Somehow, I doubt one more thread will help.
Read the lube order.
Deviate as you feel the need.
doghead
1,191
The correct answer is, "yes".
