- 2,420
- Columbus, Georgia
Zout you just continue to out do yourself!!![A toast to MV's :beer: :beer:](https://www.steelsoldiers.com/images/smilies/beerchug.gif)
When it comes time to replace, IF ever, they are much, much easier to work with than copper. They would be easier to replace if there is a malfunction. I worry more about copper getting damaged, i.e. bent and kinked, than the nylon. You can get a fairly decent bend with the nylon without kinking. As long as they are clamped and dressed up properly, the y should wear just fine.Do you think that this tubing will have the longevity of copper lines?
Could I trouble you for a pic of the underside?::snip:: LARGE heavy washers on the underside.
Sure thing. Just ran out and took these.Could I trouble you for a pic of the underside?
And based on your mounting, what kind of capacity will you get with that crane/mounting setup? EDIT: Nevermind, I missed your above post
Installed a mtvr ladder on the tailgate, lollipop lights, led turn signals, and convoy light kit. It's a little bit brighter at night now.
