Is there any chance of damage to a sprag transfer case with this setup. The wheels will always freewheel at the same speed.You mean, like this guy?View attachment 453146View attachment 453147
I'm not understanding your question? The front sprag only engages when the rears spin more than 7% ahead of the front. So basically the front will never engage in this setup. (I guess it could spin up the rear if it was hooked to a lot of cars and you goosed it hard at the start)Is there any chance of damage to a sprag transfer case with this setup. The wheels will always freewheel at the same speed.
That's it.....guess it was a 5 ton instead of a deuce.You mean, like this guy?
Hmmm.....I did keep all the receipts for parts and materials that have went in to the FEMTT project, but I have not been 'brave' enough to total them up!Soni, I am NOT trying to throw you under the bus and get you in trouble with your significant other.....But have you kept track of the man hours and money that you have invested in this project? Your work is awesome and I look forward to seeing more of your projects!!!
Looked like his ROPS was removable at the bases.Soni, How do you access to the engine if you need to service or remove it?
Yes the ROPS is bolted to the frame with six large bolts and is removable if I have to pull the engine. That's what the D-rings are for at the top of the ROPS. Pretty much everything else cane be serviced through all the access panels though. Also the fenders come off with removing just a few bolts if better side access is needed.Soni, How do you access to the engine if you need to service or remove it?
It is going to be my "regular tan"......lolCant remember if your going your regular tan or going to try out green!
