ATPTac
- 5
- 16
- Charlotte, North Carolina
Well, we went and did all the title work and picked up our 1976 Kaiser Jeep M35A2 yesterday
. I've been on the hunt for a Deuce for a little while now and finally decided on this one. Has a C turbo, White Multifuel engine, newer vinyl top, 11.00x20 tires (not in very good shape) and a few customized options the previous owner put on it.
We picked it up last night after work, and it was starting to get dark out, having never really driven one before it was a little nerve racking driving it for the first time in the dark (had a few brain farts on the shift pattern) during rush hour traffic. But it arrived safely at its temporary home. Definitely going to be upgrading the headlights in it at some point, they were ok, but not nearly bright enough for my taste.
Now, on to the "to do list":
The J-pipe has rusted out and has a pretty significantly sized hole on it, not super concerned with that right now but I will be addressing it at some point.
It has what appears to be a leaking wheel cylinder on the right rear. This is first on my list of things to do. I'm planning on going ahead and replacing all 6 wheel cylinders, the master cylinder, replace all the brake lines (hard and flex), and potentially replacing the air pack. Not 100% sure I'm going to worry about the air pack right now, but the rest is definitely getting replaced before anything else is done to the truck.
Both front axle boots are leaking. I haven't started looking into whats involved in replacing those, but I've heard its pretty straight forward.
I noticed tonight when I went by to check on it (and just sit in it and soak it in), it has a pretty steady fuel leak. Now pardon my lack of knowledge on the component names and locations, but its coming from the line running into the back of the 2 fuel filters towards the firewall of the truck. The line that's on it is a clear(ish) hose that goes into a fitting on the top of the rear filter. I haven't isolated exactly where the leak is coming from on the line being that it was getting dark, I just saw it collecting on the bottom of the line and dripping down. I'm also not sure if the line was routed correctly (I'm sure someone here will know), it ran between the filters and the engine block, which leads me to believe it might have rubbed a hole in it on the block. Not really sure either way, but I want to get that fixed ASAP as well.
Beyond those things listed it just seems to have the average "40 year old truck" leaks. When I was draining the air tanks (which is a complete pain to get to with the 11.00x20 tires) I noticed the inner most tank started having some kind of nasty looking sludge come out when it was almost done draining. Not sure what that's about, if anything.
Now onto the upgrades I'm planning on for it:
I plan on repainting it to either straight 383 green or 3 color, haven't really decided yet, and that's not going to happen until at least spring. Also when doing that I'm going to rhino line the bed and cab floor.
Remote reservoir kit. After checking the brake fluid in it, I now see why everyone complains about the MC location...
Going to single it out also with 395's. Haven't decided on wheels yet, I like the look of the MRAP wheels, but also am contemplating going with some of the custom wheels that enable you to not have to flip the rear hubs (i.e. the Eastern Surplus wheels, not really fond of the price though). I'll have to figure that out when the time comes.
Going to put spin on oil and fuel filter conversions on it.
I'm still undecided on the top. It has an insulated soft top on it right now, but I'm thinking about putting a hard top on it and insulating that. The truck is going to eventually end up the NC mountains, which get pretty cold in the winter.
I'm sure there's more I forgot to list, but I think that covers the majority of it.
To summarize, it definitely needs some work and upgrades, but I look forward to getting it back in shape. The biggest selling factor for me on this particular truck is that it has practically no rust on it. So I was willing to overlook a lot of the mechanical issues with it that can be fixed with time and $... Unlike rust.
