Correcting a mistake
AN/ARC186
Graham,Washington
One thing I've never understood is why Dodge didn't use it's Ramcharger base to build a CUCV.
My son is getting ready to head to North Carolina for a job and his old 84 Ramcharger was pretty tired.
So, rather than do a normal rebuild he decided he wanted do turn it into something more like an M1009.
New engine, rebuilt transmission and a NAPA stores worth of new parts we set to work.
Bought the RAPCO 383 CARC substitute to paint it with, starting in the engine bay.
FT POWELL found us a CUCV bumper and grill guard complete with clevis's, thanks Ed!!
Dug through my stuff and came up with an antenna mounting bracket that was posing as a doorstop.
The build is underway! Pics to follow...
M813rc
3,872
Near Austin, Texas
Dodge did compete for the CUCV contract, including offering the Ramcharger. Ford competed too. Chevrolet won the bidding.
Cheers
rickf
2,243
Pemberton, N.J.
I would guess that Ford and Dodge did not offer a diesel which was probably a requirement for the bid.
rickf
2,243
Pemberton, N.J.
The 7.3 would have been way to heavy for the front end of a Bronco. I would have liked to have seen the redesign on that. That or the Cummins powered Ramcharger would be big time driveline destroyers. You would basically have to put one ton drivelines under either one.
AN/ARC186
Graham,Washington
Been busy working on this as well as my normal job. My sons been doing the majority of the paint and body work since it's his truck.
Replaced the worn out seats with new reclining buckets, fabbed up base adapter plates so they'd bolt in.
Got the engine and transmission in. Engine is a 5.9L 360 gas. Trans is the ol reliable 727 Torqueflite.
Modified an antenna mount to accept a standard 102" whip and set that in place. radio transmits and receives loud and clear.
Also had a sight laying around from a Gau-2B cradle so I figured I'd replace the broken hood ornament with something a bit more appropriate.
replaced the broken grill with one from a newer P/U
the last two pictures are before we started the work.
more to follow...
AN/ARC186
Graham,Washington
Actually, the interior was originally red, he repainted the door panels and dashboard black. We replaced the seat belts with new 3 points and he has painted all the exposed metal that was black with 383 carc substitute green.
AN/ARC186
Graham,Washington
Well, after a month or so and many parts runs later we're 95% finished.
He'll be heading from the Great Pacific Northwet to N.C. on Tuesday to connect up with another Steel soldiers member. Thanks Dale!!
Still a few minor things to do once he's there but I figure it will keep him occupied.
