Does anybody have any experience with this particular impact:
http://www.harborfreight.com/3-4-quarter-inch-heavy-duty-impact-wrench-66984.html ? I'm trying to figure out the best way to remove/reinstall the lug nuts without spending a ton of money. I also saw a 3/4 drive torque wrench at Harbor Freight that goes up to 300ft/lb, which is less than the specified torque spec on the A2. I went on the Snap-On truck and he had a 3/4 drive torque wrench that goes up to 700ft/lbs (I think), but it was $780
![Shocked :shock: :shock:](https://www.steelsoldiers.com/images/smilies/icon_eek.gif)
. What do you guys use to torque the wheels other than just leaning into a cheater bar?
I'm a little concerned about the rear budd's trying to turn when I go to remove the lug nuts, other than a porkchop are there any other options to prevent that? Or is using an impact usually good enough to get the nuts to come off without them both spinning?
