UPFINN
- 4
- 18
- Ishpeming Michigan
I wish it could wait but I need to use it.My cold weather issue is this: Is it too cold to go outside? If the answer is yes, the truck can wait till Spring.
Well I let the torches warm up so they worked again and after heating one of the 1/2 inch npt plugs in the manifold for about a minute I was able to get it to move with the wrench and hammer. Next up is the temp sensor. I want to get that loose as I will likely have to take it out to get to the 3/8th plug below it. The sensor takes I think a 15/16 socket, but the socket collar is pretty narrow so the wrench was trying to round the corners. I don't have a 15/16 deepwell and I'm afraid to use heat. Might try locking pliers and a cheater pipe.
I tried getting the 3/4 inch npt plug out of the water pump but my torch quit working so I couldn't heat it enough. Will try again tomorrow.
Depending how this goes I might need to find a 15/16 deepwell along with a few 8-point sockets.
I measured the plastic battery box in the truck and it is only 12.5 inches wide. Only enough room for walmart 850cca everstart maxs, 6tls, or perhaps a referb group 27 battery. Right now I will likely just get the everstarts. Would like a group 31 but they wont fit
