- 1,425
- 38
- 48
- Winter Haven, florida
I have tryed several times to load pic's and it locks my PC up? Pic loading has change from the way it was last week?
It has come to our attention that there is a security issue in the uploader.swf file included as part of the Yahoo User Interface (YUI) library included in vBulletin 4. As the version of YUI included in vBulletin is end-of-lifed, Yahoo will not be fixing this issue. Their recommendation is to remove the file from your server. We recommend that you replace this with an empty file of the same name (attached). What this will do is force vBulletin to use a fallback javascript based uploader which is already provided in your system.
See: http://yuilibrary.com/support/20131111-vulnerability/
The vulnerable file is also present in the vBulletin 5 download package though not used by the vBulletin 5 front-end. We recommend that you delete the file and replace it with the attached file.
We have also updated all download packages for vBulletin 4.X and 5.X with the new empty file.
To resolve this issue take the following steps:
Delete uploader.swf located in clientscript/yui/uploader/assets or /core/clientscript/yui/uploader/assets
Replace it with the attached file.
Alternatively, you can download the vBulletin package for your version and replace it from that download.
Note: We will not be fixing the vulnerability in the SWF file directly nor do we plan to take any other action on this issue at this time.
The original screen that you used to see will not display anymore. It's going to have to be a one by one upload now. The screen will now give you a browse button to allow you to go search for the file you want on your desktop.The box that has pic's in it is a small amount of pic's i have on file, i am unable to get to the pic's i want in my file. I can click on "add files" and open up 5 or 6 "browse" box's and load it up but it will need post them and lock it up.
Yup, going advanced means the manage attachements uses the uploadattachment.php file instead of the YUI uploader.swf in the quick reply window.View attachment 471670View attachment 471669
The quick reply is what I had Tried, Turns out Go advanced , manage attachment and Looks like I can add Files and they pop right in, sorry just two Jpegs I tried and they worked
No.Is this why I lost all the quick buttons on the reply box?
