epitts
- 1
- 18
- Terre Haute, Indiana
I am working on a 701 for a friend. It has not run in several years. I changed all filters but air filter, checked the wiring and all looks good. I primed the unit the best I could with priming lever, pulled and checked glow plug all good. Got the unit running and making power, charging system works fine. I used two motorcycle battery's in place of the 4HN battery.I have two questions 1. When first started it it has voltage on LO per my meter but after running for a few minutes every thing turn okay. No power on LO normal readings on L1 & L2. Question 2 And don't laugh at me how do you run cable to the hook up with the ASK on?
Thanks for your help
Eric
Eric
