Does anyone know what this is used for ??????
MtnSnow
15
NSL, UT
Can I piggy back on this thread..... I found a bunch of these in my side tool box and I have no idea what they are for...Can you help?
I couldn't find any part number stampings
WillWagner
3,039
Monrovia, Ca.
ST-910...looks newer and in better shape than the one at work. I would bet your next paycheck, that is a liner driver for the C series engines.
Hard Head
22
Greenville SC
mount a board on top of the drop sides. My truck came with them attached. Keeps the sides from folding down and it matched the height of the back and from bed with the board attached.
MtnSnow
15
NSL, UT
by chance do you have a picture of them in use or how they were attached....I'm having a hard time envisioning in my minds eye..
tennmogger
556
Greenback, TN
HarleyBoy, if the outside dimensions of the rear flange is right at 140 mm (could be 136mm if earlier version) then the device could be a seal driver for the output seal for the portal gearbox of a SEE excavator, 419 Unimog, as used by the Marines.
I would like to get this driver unless it proves to be a liner driver as suggested by WillWagner.
Bob
harleyboy1
Lake City, Fl.
Bob
The outside measurement is 165mm.
tennmogger
556
Greenback, TN
How 'bout that. I got to thinking in my sleep last night that the 140 mm (from memory) is inside diameter. So I went out and measured a spare seal this morning and it is 140 x 165 x 9.5/12.
165mm!!
That 165 mm OD is too much of a coincidence. If this is not a outer seal driver for a Freightliner SEE FL-419 then it would certainly work for one, right down to the mm.
The inner diameter cylinder could possibly fit the input seal for the same portal hub. I don't have one of those seals handy to measure but it looks about right (4-1/2" in your picture).
Do I get the prize? :)
Bob
harleyboy1
Lake City, Fl.
Just got seal driver and a surprise driver as a bonus boxed up. Will take to post office in the morning. Hope you can use both tools.
Thanks, Art 386-867-0952
