wb1895
- 16
- 18
- Lexington NC
Just looking at that makes me want a beer
Nick(bgekky) used a horrible freight motor picker to pull his multifuel!Do you think a normal cherry picker with a heavy enough load rating could pull the motor?
If so, I can see what I can come up with as far as getting one to take up there if you want... Or if you just want to do an in frame rebuild that works too. Just trying to give you options.
Holy crap I found it.Nick(bgekky) used a horrible freight motor picker to pull his multifuel!
I am so confused. Please elaborate.air coupling
X2That picture scares me knowing where that cherry picker came from!
Wire connected to nothing, "air coupling".I am so confused. Please elaborate.
Do you have a link? I'm still trying to find a source for the 12 point rod bolts!Hercules sells the upgraded rod bolts. But if you can find new rod assemblies for a reasonable price that wouldn't be a bad idea either.
Good info thanks. I have a brand new LDT to put in the duece and my cherry picker won't lift that high and I didn't want to go through the trouble of pulling the front tires to drop the front low enough.I bought a HF Gantry that was on sale and had a 20% off coupon! got it for around $350 and it made the job easy. Plenty strong to swap out a multifuel, top beam didn't flex one bit. Did the swap all by myself.
One of those would be useful to have for not just engine swaps. What is the load rating of it? Do you think it could pull a bed or no? I might have to look into getting one of those down the road.I have another brand of cherry picker that looks exactly like the HF one and is rated to 4 tons. Lifted the multifuel with no problems but that was only to move it around the shop as it can't lift high enough to use on the truck. I bought a HF Gantry that was on sale and had a 20% off coupon! got it for around $350 and it made the job easy. Plenty strong to swap out a multifuel, top beam didn't flex one bit. Did the swap all by myself.
If it can lift a multifuel then a bed would be a cake walk as far as weight. Balancing the bed could be fun but it weighs around 1400 pounds for a 12ft bed. Multifuel weighs about 1800 pounds.One of those would be useful to have for not just engine swaps. What is the load rating of it? Do you think it could pull a bed or no? I might have to look into getting one of those down the road.
