LDT-465 rebuild
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
Do you think a normal cherry picker with a heavy enough load rating could pull the motor?
If so, I can see what I can come up with as far as getting one to take up there if you want... Or if you just want to do an in frame rebuild that works too. Just trying to give you options.
Nick(bgekky) used a horrible freight motor picker to pull his multifuel!
1,165
Wire connected to nothing, "air coupling". ;)
Oh. That was the prototype mockup. It is wired up now, with packards and everything.
Terexts
Winder, Ga
Doing a inframe is no problem with these engines. We do inframes everyday at work on newer semi trucks. Once you have everything out of the way it will be easy to access. Make sure to check the crankshaft really good for scratches. Checking liner protrusion is a good idea too.
eagle4g63
35
North/west Indiana
Holy crap I found it.
I have that same hoist, they are actually very good. However, I don't think I would try it on a multi.....actually, I KNOW I wouldn't....I DIDN'T!!!
But again, they are worth buying if you need an engine hoist, even to just pick big stuff into the back of the truck, or out of.....I picked up a tote that was just under half full of oil out of my deuce with it, no problem....
welldigger
17
Benton LA
I wouldn't say they make complete engines. They are not the origional hercules diesel. They opened up after hercules went defunct to supply repair parts.
Rusty nuts
Oregun
I have another brand of cherry picker that looks exactly like the HF one and is rated to 4 tons. Lifted the multifuel with no problems but that was only to move it around the shop as it can't lift high enough to use on the truck. I bought a HF Gantry that was on sale and had a 20% off coupon! got it for around $350 and it made the job easy. Plenty strong to swap out a multifuel, top beam didn't flex one bit. Did the swap all by myself.
DieselBob
15
Arnold Maryland
Good info thanks. I have a brand new LDT to put in the duece and my cherry picker won't lift that high and I didn't want to go through the trouble of pulling the front tires to drop the front low enough.
ATPTac
Charlotte, North Carolina
One of those would be useful to have for not just engine swaps. What is the load rating of it? Do you think it could pull a bed or no? I might have to look into getting one of those down the road.
welldigger
17
Benton LA
If it can lift a multifuel then a bed would be a cake walk as far as weight. Balancing the bed could be fun but it weighs around 1400 pounds for a 12ft bed. Multifuel weighs about 1800 pounds.
