looking for this TM 9-2320-361-10
Recovry4x4
LLM/Member 785
1,807
GA Mountains
While that manual is available in lots of locations, you will find this printed inside.
DISTRIBUTION STATEMENT C. Distribution authorized to U.S. Government agencies and their contractors. This
publication​
IS required for administration and operational purposes, as determined 15 December 1988. Other
requests for this document shall be referred to Commander, US Army Tank-Automotive Command, ATTN:
AMSTA-MB, Warren, Ml, 48397-5000.
T
DESTRUCTION NOTICE For unclassified, limited documents, destroy by any method that will prevent disclosure of
contents or reconstruction of the document.
The August 2006 version is Distribution Statement A which is unlimited release.
Make a difference? Probably not! FYI
SCSG-G4
PSVB 3003
3,296
Lexington, South Carolina
If a manual is NOT Distribution Statement A in it's most recent form, it's very naughty to pass out copies, in printed or electronic format. That is why there are many manuals not available here on this site (when the TM section is working).
gringeltaube
Staff Member
2,421
Montevideo/Uruguay
publication
T
The August 2006 version is Distribution Statement A which is unlimited release.​
Thanks for the heads up, Kenny. I'm deleting my post with that TM attached, just in case...
Hope the OP has already downloaded it.​
G.​
jasonjc
283
Gravette Ar.
I forgot about the Distribution Statement "C" thing. But as Kenny says the 2006 is "A". It makes no sence that the 1988 is a "C":confused:. My bet is that it was a typo. But my bet is only good for $0.02. TM 9-2320-260-10 jun 85 does not have any statement and TM 9-2320-272-10 aug 86 is an "A" TM 9-2320-361-34 may 92 is an"A".:confused:
rlwm211
Guilford, NY
It is odd that all the rest of the manuals in the series are classified A for public distribution but the Operator's manual -10 is not. Leave it to the military to do something like that.
RL
Recovry4x4
LLM/Member 785
1,807
GA Mountains
RL
Actually, that is somewhat common. Some of the most useless manuals are Dist C while many of the current ones are Dist A. Common Sense in Gov't is the oxymoron of the day!
425LRS
Whitmore Lake, Mi
I used to do a lot of Distribution A drawings- that all kinda changed ( or at least was looked at more closely) after 9/11. Now it's often Distribution D- To release a distribution A document generally means it has to go through another department (G2 if I remember correctly) to ensure nothing is accidentally disclosed that should not be. So it is "easier" to have a distribution statement other than "A" in many cases.
m16ty
211
Dickson,TN
The LOGSA site mentioned earlier in the thread is no longer available to us lowly civilians.
cobra5
194
Stevensville, Montana
Do you have a link stating this because I just did a search and it brings up manuals. It will only open manuals coded A. I have both the 1988 and 2006 version of the manual asked about and the 1988 is coded C and the 2006 is coded A.
