Air Dryer for an M35A2
cranetruck
75
Meadows of Dan, Virginia
Bringing this thread back.
I ended up getting one of the A3 type air dryers. The guy selling it was worried that it is listed in the CTIS(should use lots of air) section of the A3 TM. In all of the searching I have done, NONE of the air dryers for trucks list a cfm. Is this a concern I need to worry about or not. Everything I have read leads me to "NOT", but I wanted to be sure.
The CFM that is seen by the air dryer comes from the compressor, about 7 in the case of the deuce and shouldn't be an issue. The instantaneous CFM demanded by Airpak, CTIS, tools etc is supplied by the tanks.
rrrr
Missouri
I put an alcohol system on mine as well as automatic water drains on both tanks. No issues with moisture even in the teens for temps. Do a search on this forum and you'll find all the info you need.
joeM62
Cedartown/GA.
If you guys don't would anybody have pics of how theirs is set up. I had an ideal about doing this a few years ago but didn't go through with it then because I had sold the truck.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
So my air dryer showed up, now I need to decide where to plumb it in the air system. I am thinking of putting it under the hood. Is there a better place to install them?
gimpyrobb
27,785
748
Cincy Ohio
Hellz no! Its like 7* here right now. That will be a job for later. I did find an installation manual that gives specifications on how far from the air comp. to mount it and to put it in the air line before the "wet" tank though. I think on a deuce(A2) the perfect spot would be in the tool box under the driver's seat by the running board. (Or mounted to the back of it)
welldigger
15
Benton LA
Hey gimp, which air dryer do you have? I pretty much know which one I'm going to get but as with everything I take my sweet time.
Edit: Ok nevermind. I read back in the thread and I see you got the pure air plus. Good unit, though not the one I plan on using.
Merc1973
Sykesville, MD
Haha, just checking. My tanks spray plenty of water out when I drain. What is the model number for the pure air plus? I can only find "repair kits" for sale, not installation kits...
welldigger
15
Benton LA
I don't know all of the places that sell the pure air plus but I know eriks has the complete units. Not a horribly outrageous price for them either. I'm going with a bendix ad-9 clone.
Merc1973
Sykesville, MD
Thanks For the info about Eriks, Do you have a link for the clone which I assume is cheaper?
