i would use the banks if i had the money i have the oil return plate of the other truck, now i just have to decide if i should rebuild the old turbo or use it as it is, it has a little shaft movement but the blades don't touch the walls. also ive been chasing this one down for some time is there anyway to put the 37s on without spacers is there a aftermarket black powder coated rim or something i can use?I have an aftermarket Banks kit on mine, found a good deal on a used kit that came with a passenger side manifold which is a lot easier to use then the 6.5 manifold. With the GM 6.5 manifold, some of the guys are using 2 manifold gaskets stacked to get clearance for the injectors and some guys say they didn't need the extra room,. I kept my mechanical lift pump, drilled a hole and welded a piece of tubing to the fuel pump adapter plate for the oil return. For your manual boost controller, everyone refers to it as a "turbo master". Its just a spring installed in place of the vacuum servo, or whatever its called. There is a few DIY videos on YouTube on how to make them.
I would recommend getting that turbo on while your truck is apart, it is a big job and way easier if you have the fender off on that side.
i can just run the exhaust right in the stock dual pipes cant i ?Nice start on your truck, I totally agree what evildoer just said recommend getting that turbo on while your truck is apart, it is a big job and way easier if you have the fender off on that side. I added extra gaskets on mine and used stock injectors and ran the exhaust on the out side of frame. Have fun with your project.
