ALA2
- 0
- 0
- lacrosse wi
Hello all, today I installed a new top on my bober there are 2 brackets sticking out the back of the frame work on the cab.These would be about neck high maby a little higher.Is there supposed to be a bar or rod going left to right to support the top or is this something someone added. I can build a bar to work but it does not look like it would be wright or I cut the brackets off .They will poke threw the top if left alone.THANK YOU ALL AL
