milradioman
- 0
- 8
- Kooskia, Idaho
Anyone found an easy way to remove and replace the mechanical pump? The biggest problem I have is getting access to the bolts, what a pain!
Beer and a friend. Easier for you, not so much for him.Anyone found an easy way to remove and replace the mechanical pump? The biggest problem I have is getting access to the bolts, what a pain!
I recently replaced one. I ended up using a short flex head ratchet and a wobbly extension on one, and without extension on other, if I recall. It is a tight spot for a couple of the bolts.Anyone found an easy way to remove and replace the mechanical pump? The biggest problem I have is getting access to the bolts, what a pain!
X2 on that. The only real problem I had after that was ensuring it was lined up correctly on the shaft before threading it on. I missed the first time and must have knocked it loose but used a little elbow grease the second to motivate the fuel line to stay in place and it worked fine.The huge key to success is threading that line on first before bolting the pump to the block. Once it is rigid, you are almost guaranteed to never the get the threaded line started.
My 1028 still has the mech. pump , but I'm considering the spin on mod and will convert at that time also.
Well, I made my 650-mile recovery run with a fried alternator and no electricity. When I started, I thought it was a tired battery, and I figured I'd replace it when I got home. I was well under way when I learned otherwise. I used a jump box to get it started, and was careful to never turn the engine off after that.Now, are there any advantages to a mechanical pump? None that I can think of.
This.Well, I made my 650-mile recovery run with a fried alternator and no electricity. When I started, I thought it was a tired battery, and I figured I'd replace it when I got home. I was well under way when I learned otherwise. I used a jump box to get it started, and was careful to never turn the engine off after that.
Sometimes it's a good thing to not need electricity.
My fuel pump went out early spring and I replaced it with a Carter pump. I noticed it was different than the OEM one at the time. It is still working for now. I read how you said they were selling the wrong pumps. Which is the right one and where can you get it? I remember you talked about a Delphi. I would like to have one on hand when the Carter gives up. The correct pump has the spring on top I believe. I saw one on eBay but it was $50.I can do it from the top side in about a 1/2 hour. My Wife done a few for me for $40. She is not so easily amused anymore. But doing it topside is the way to go. Only thing I go under for is the 2 M6 cover plate bolts. And letting everything loose is the key. Tighten only after everything is started. My way you remove the right alternator and bracket. It is EASY. Have a Great Day.
