Ok so we got slow and bored today at work. it was raining and sleeting and I had a free bay so we decided to install my new Heavy duty headlight wiring harness.
Install went fine. I checked the lights and appeared to be operating fine. When time to leave no lights at all. Luckily it was still light ok so I drove home. Once I got home checked everything again. No lights at all, including brakes. Checked fuses all good. Found a red wire with an inline fuse unplugged that appears to run into the back of the fuse box. I plugged it into the open continuous slot on fuse box and voila lights, well most lights. Reverse and appears brake lights stay on even when you turn the lights off or turn the key off. Just a side note I don't think the reverse lights were working before. Also after installing the new wiring harness I didn't look at the brake lights so I don't know if it was doing it right after the install. I did pull the relay at the top right of the fuse box to see if it was bad due my horn not working so I might of pulled the red wire out then, not sure.
So to sum up brake and reverse light want turn off, no horn, but have new headlight wiring harness. I am at a loss. Has anyone else had this problem.
1984 M1009
24v
![Banging Head aua aua](https://www.steelsoldiers.com/images/smilies/icon_smile_banghead_125.gif)
1984 M1009
24v
