plumkrazy
- 1
- 6
- Abilene Tx
Great attention to detail! Put me down for 1 if they are put up for sale. Good luck--Allen
Doghead, after doing some research on the drive side and the slack side of the belts it looks like you were mistaken. I do have the idler mounted on the slack side. Please see diagram. looking from the front of the engine, D1 in the diagram being the water pump and D2 being the fuel pump and the belts are turning the same direction on the truck.
Either the crank pulley drives the accessory drive pulley (I agree that this instance the front geartrain crankshaft mounted gear is the initial driver, which is fixed to the crank pulley by the crank snout, but that simply means you must follow the rotation from the crank-the input- through all the gears up to the aux belt output from the geartrain) or you have FM driving it.That's the problem Bob, the engine does not drive that pulley.
Choose you words carefully, the engine drives everything!
The accessory drive pulley drives the water pump.
