My new to me MKT-75A
MWMULES
349
DESOTO, KANSAS
They are for more air circulation when you have the foul weather covers on the sides. They push the bottom of the cover away from the walkway so air comes in low and goes out the roof vents, sets up natural cooling.
http://bulkfoodrecipes.tpub.com/TM-10-7360-206-13/TM-10-7360-206-130080.htm As DH would say it's in the manual. Also good for spearing trash on the ground!
Augusta, New Jersey
View attachment 487882View attachment 487881View attachment 487883One more question for the MKT God's:not worthy:. What/where do these go? The TM say they are "Strut Fabric Holdout Assy". I don't see where or how they work.
Jasonjc,
The solid poles with the pointed ends, insert into the sidewalkways. The larger end goes inside the holes, 4 on each side. The pointed end faces out and the screens or walls attach and allow air to move through the trailer. Picture of my screens set up in this manner. Hope this helps.
John
jasonjc
289
Gravette Ar.
Jasonjc,
John
Cool thanks for the info and pic's. Come pay day I'm ordering hard copy TM's. They are a lot easyer to flip thought. I'm also getting the thumb drive from SSG.
61sleepercab
Walton, West Virginia
From been there done that school of education, use nylon straps between top hardware and catwalk edge were GI tent poles go in, because wind will pick up tent canvas awning and tent poles will lift out of catwalk holes and you have a mess if you are not using sides. Mark
jasonjc
289
Gravette Ar.
WOW!!! Excellent haul. I also see you have a "few" green iron beasts in the backyard...
Yes just a few:
2) M818 5 ton Tractor
1) M127A2 12 ton flat bed trailer
1) M129A3 12 shop van trailer
2) M109A3 2 1/2ton shop vans
1) M36A2 2 1/2 ton long bed
1) M35A2C 2 1/2ton drop side
1) M35A2 w/w 2 1/2 ton
2) M35A2 2 1/2 ton
1) M530 2 1/2 ton fire truck
3) M135 2 1/2 ton GMC's
6) M105A2 1 1/2 ton trailers
1) M103A2 1 1/2 ton trailer w/ 2 10K gen sets
1) ENG-3 lube trailer
1) M149A2 400gal water trailer
1) MKT-75A trailer
Another Ahab
4,556
Alexandria, VA
Yes just a few:
2) M35A2 2 1/2 ton
1) MKT-75A trailer
That might qualify you for designation as a battalion.
Or am I wrong, should it be regiment?!
SCSG-G4
PSVB 3003
3,378
Lexington, South Carolina
And the burners are the latest V3 type (wider range of heat output, from 11000 BTU/hr up to 60500 BTU/hr vs 20000 to 55000 BTU/hr on the older models).
MWMULES
349
DESOTO, KANSAS
And thanks to jasonjc I have some Cambro containers for my TFK. Wish we would of had more time to visit. :beer:
102_4268.jpg 102_4266.jpg A little power washing and some bleach water and they will be ready to go for Memorial day.
jasonjc
289
Gravette Ar.
Well I got 4 more MBU's today ,so now I have all 6. I just have to see if they all work or not. Now to find 2 of the roof vents and new travel covers and I should be good to go. Well that and some TLC.:beer:
jasonjc
289
Gravette Ar.
I rigged up a power cord yesterday and check my mbu's. I checked one of the 2 I got from MWMULES, it had like 2 hr on it. It fired up on the 2nd or 3rd try, been sitting for a long time. The other ones I got saterday , the better one had 26hr the other 3 all had around 425hr on them and look well used. I try to get one of them started, took a lot of pushing of the start button to even get it to try to lite. The button mite be going bad. It took 4-5 trys to start but it did and ran fine. Still need to try the other 3 of those and the other one from Mules.
So know I need to figure out how to cook with this thing in time for the KAMO rally:razz:
jasonjc
289
Gravette Ar.
Some thing else I just thought of, my M149A2 has a 1" quick cupler on it that the TM says ,I think I read that, is for a MKT. But I have not seen in the MKT TM's any thing about hooking it to a M149a2. Does it, one the newer one maybe?
