rustystud
- 2,685
- Woodinville, Washington
A lot of people have problems with fuel line replacement as the stock fittings are an odd duck 5 AN (37 degree JIC ). This is what I have done to my MEP-003a. This is also what we use on our busses. There "DOT" brake line hose with compression fittings. I changed out all the lines after I cleaned up my fuel pumps. Also removed one pump and am keeping it for a backup.![Vacation Orcas Island 4-15 to 18-2014 096.jpg Vacation Orcas Island 4-15 to 18-2014 096.jpg](https://www.steelsoldiers.com/data/attachments/334/334362-2ce8b1c4ea92a3b099ca718b5f3440df.jpg)
![Vacation Orcas Island 4-15 to 18-2014 099.jpg Vacation Orcas Island 4-15 to 18-2014 099.jpg](https://www.steelsoldiers.com/data/attachments/334/334364-9215e5aeb1aceaa8b582114cd59d97e2.jpg)
![Vacation Orcas Island 4-15 to 18-2014 100.jpg Vacation Orcas Island 4-15 to 18-2014 100.jpg](https://www.steelsoldiers.com/data/attachments/334/334365-3a27ff998a6cc33e33bfca4f48b3a1f4.jpg)
![Vacation Orcas Island 4-15 to 18-2014 101.jpg Vacation Orcas Island 4-15 to 18-2014 101.jpg](https://www.steelsoldiers.com/data/attachments/334/334366-8806c1e7ad8e2e6eb394383b11a23d01.jpg)
![Vacation Orcas Island 4-15 to 18-2014 102.jpg Vacation Orcas Island 4-15 to 18-2014 102.jpg](https://www.steelsoldiers.com/data/attachments/334/334367-7de2b4e541d063bba7db75f9e0d4fb89.jpg)
![Vacation Orcas Island 4-15 to 18-2014 118.jpg Vacation Orcas Island 4-15 to 18-2014 118.jpg](https://www.steelsoldiers.com/data/attachments/334/334369-61d4ba4440ef82ef0ce3cb6e6cc54927.jpg)
![Vacation Orcas Island 4-15 to 18-2014 123.jpg Vacation Orcas Island 4-15 to 18-2014 123.jpg](https://www.steelsoldiers.com/data/attachments/334/334370-80aaed62eba276a8bb05f8bba126aebe.jpg)
The only problem is you have to make up a fuel tank suction pipe. I took one of the 90 degree fittings and drilled out the bottom to 5/16", then using a 14" long piece of 1/4" copper tubing I soldered it in place. Works great !
I should mention that the hose is only $1.00 per ft. If you have to replace a line all you will have to buy is a new ferrule and the hose.
![Vacation Orcas Island 4-15 to 18-2014 127.jpg Vacation Orcas Island 4-15 to 18-2014 127.jpg](https://www.steelsoldiers.com/data/attachments/334/334374-dbc578e833d6f0f5e3ae83148601fa46.jpg)
