Some are zipper boots and some are solid one piece.Is that the zipper part on the front axles?
Ok, yeah I have the zipper boot.Some are zipper boots and some are solid one piece.
I'll check it when it stops raining, I'll take picsCheck that whole rubber boot with the zipper on it, it may have had a small tear before or you could have torn it in the process of trying to get out. Like mentioned before if it is torn at all it's probably full of mud and grit now.
I plan on dropping the fluids, and changing the fluids.Your TM probably has a section that tells you what to do BEFORE you
go FORDING Mud Bugs / rivers etc. Perhaps read that and realize
what you did not do and go from there. It is not just the axles probably.
If it were mine all axles would get serviced. You probably got mud
and yuck into the flywheel area. Remember the Axle breathers
were submerged so your diffs are probably full of it too. The TC
might be compromised too.
There may be a TM section to deal w/ floods, I would not doubt it
there pretty all inclusive.
Glad your home, live and learn, now do your PMCS from bumper to bumper
and gether good to go again.
or not, and runer till she drops! HA!
Oh no doubt. I'm going to go to tractor supply and get two buckets of 80-90 and some grease for the bearings.Stick a water hose in the hole in the bottom and let it run on low for a few minutes, then remove it. Repeat as needed. You will need to go through all of the hubs though. No getting around that.
Jeep, on a side note, any update on the trip to Houston?Stick a water hose in the hole in the bottom and let it run on low for a few minutes, then remove it. Repeat as needed. You will need to go through all of the hubs though. No getting around that, unless the hubs weren't submerged.
Your scaring me saying 10 gallons isn't enough. LO states 12 qts x 3 for diffs, and 5 1/4 qts for transfer. That comes out to ~10 1/2 gallons, should I go ahead and to the transmission also?Still pending but it is a go. Ten gallons of gear oil is not going to be enough. Also, keep in mind that a regular deuce hub takes over a pound of grease to pack one hub. I buy my grease in four pound tubs. Red grease. You are going to need a lot of grease and oil.
Looking over the tm I don't need to pull axles, that's a relief, although I probably will inspect just to make sure. Pretty simple procedure for front, haven't gotten to the back yet, but looks to be simple enough.why do you put so much grease in there ? all that grease comes over time as you you,s a grease gun. you pack them like any other truck.
