DaveB10
- 0
- 1
- Hamburg, Pa
Hi! Since you have done so well in finding connector part numbers I am hoping you may have some advice for me. My MEP-003A was warming up "prior" to switching to house load when sparks started flying. In the ac control box/distribution box the heavy leads in P10 (7 pin male) from the generator to J10(7 pin female chassis mount) on the control box sparked and melted the connector before tripping the 40A breaker. I think what happened is one of the connector pins was corroded and heat built up till it melted the insulation between the pins...then sparks. I have a copy of the manual and no connector numbers are listed. It looks like major surgery to get to the J10 in the box. Any suggestions?? Even if I get a used control box I still need the plug end from the gen head. Thanks, Dave.
