Over
- 6
- 18
- Cave Creek AZ
I did a search and could find nothing on this. I have a M923A2 that the torsion? bars separated from the rubber and is causing the axle to tilt so the u joints hit. Funny thing is they both came off (rubber seperated) on the front rear axle part. They are now hanging a bit below the attachment point. What would cause this and where can I find a couple? Not sure I am calling it by the right name. I figure you replace the whole bar as the rubber is probably vulcanized to the joint. Thanks in advance! Also is it the same part in the M923, A0 and A2?
I searched using the above title and even replaced torque/torsion with dog bones on the advanced search?
