Air Pack Bleeder Stuck
trider
Seminole, OK
Has anyone else been unable to get the bleeder on the air pack to turn? I build a power bleeder and got under there to bleed the air pack first and can not get the bleeder to turn. I appears someone else has almost rounded it prior to me. I am not sure how to get it loose. I have even tried vise grips and cant get it to turn at all. Any help would be appreciated.
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
Might try heating the body of the air pack. I'd wait till you have a replacement bleeder to install though.
Katahdin
24
Scarborough, ME
Hammer/tap on a 6-sided deep socket and wrench it off that way, use a breaker bar for leverage if needed. Of course you'll want to replace the rounded bleeder, NAPA can sell you new ones, I've replaced all my bleeder screws from there.
trider
Seminole, OK
I will go get new ones. I assume there is difference size bleeders though? Can someone tell me what size I need so I can get a new one before removing the old one? Also are the bleeders on the wheels the same size?
trider
Seminole, OK
If the bleeder screws my local auto parts store has is a little longer or a little shorter would they still work or do they need to be exactly 1.37" long?
trider
Seminole, OK
Im finding 1 1/4" long, 1 17/64" long and 1 11/16" long so far at the first two parts stores. NAPA says they have two options 1.25" long and 1.68" long.
