Drock
- 12
- 0
- Eatonton GA
So my inner fender is rusted pretty bad under the front battery to the point were it was falling through. And I also plan on installing the banks turbo. So I took the rear battery tray added an extra 4" towards the passenger fender. Then smoothed all the tabs off and added ah small filler piece to the front corner. Then I made the cover out of 1"X1"X1/8" angle iron. Added some tabs and used the original rods to bolt it down. Then I mocked it up, cut and fit the original fender brace to the cover. The idea was to make it look as stock as possible buy using much of the original pieces.![Battery tray.jpg Battery tray.jpg](https://www.steelsoldiers.com/data/attachments/343/343810-60d32e1a2c74776e5a06b90bcab2cb4e.jpg)
