EwaMarine
- 16
- 0
- Kapolei, HI
Good looking truck. Just a note, you have radial tires on bias rims. Not a good combo to drive safely on.
When your wife gets tired of the 1078 in the yard, I'll be first in line to take it off your hands...................
Nice Hmmwv you got there, you really don't stop do you?
Stoked for you! Do the USMC proud and keep her legit looking!!!!
Make sure you have 24vdc to the IP top cover. Sometimes the connection is not seated correctly or you have a bad solenoid. It should "click" when you turn on the ignition. If ran dry, it will take a while to purge.
Do you still have any of the abs units davo I have pmed you but I am new to this site I don't know if it worked ?
I want one too !!
Do you have the old 6.2, manual pump 6.5, or the electronic throttle controlled 6.5?
