Finally !! scored a hmmwv m998, LOTS to learn !! let the fun begin !!
EwaMarine
Kapolei, HI
Auction addict...We have three. two are hardtop guntrucks, and one is a cargo variant. The tan one was woodland three tone, then tan, then some weird grey scheme for Jurrasic world and then back to tan...lol.. Heres some pics of the HMMWVs here: 931226_10151687554094507_2005783994_n.jpg1504940_10152076498114507_1646494614_n.jpgpainted at Heeia for Ebbtide.jpg931226_10151687554094507_2005783994_n.jpg1622268_10203425586704503_1485042415_n.jpg
auctionaddict
15
blue ridge, ga
I think i'm gonna cry !!
New KDS smart start with controller, Ground harness, new glow plugs and new batteries.. It still wont start !!
I guess IP pump maybe ?
I have fuel squirting out of filter housing exit when I turn it over, but no fuel if I loosen the hard line at the head and spin it over..
TedG
39
MI USA
Make sure you have 24vdc to the IP top cover. Sometimes the connection is not seated correctly or you have a bad solenoid. It should "click" when you turn on the ignition. If ran dry, it will take a while to purge.
auctionaddict
15
blue ridge, ga
I do have power but didn't hear a click. I will check that, Thanks !!
TedG
39
MI USA
Place you hand on the cover and then hit it with 24vdc by plugging it in. If you remove the cover, you should have fuel in the bowl. Make sure the check valve is not clogged or stuck closed. It is on the outside of the ip cover. Are you getting fuel on the outlet of the filter that feeds the engine?
Jeepsinker
457
Dry Creek, Louisiana
Crack a couple of the injector lines at the injectors and spin it over. I usually do three lines. It will fire off and then you can tighten up the lines while it is running.
