todds112
- 5
- 18
- Teton Valley, ID
Still chasing down leaks, weeps, and seeps. I've got what appears to be an oil leak (not fuel) from behind and near the front of the IP. I see what looks like a rubber line from the block to the bottom of the IP. Can't tell exactly where it's leaking though. Will I be able to access this line without removing the IP? I think I'm going to have to remove the winch drive shaft to even be able to see well enough up in there. I'm trying to clean the area up with engine degreaser so I can tell better where it might be coming from. Mostly ends up as a thick greasy mess on the winch drive shaft. If it is a rubber line I'm guessing it will be in the same condition as the rubber fuel return line I replaced recently, and a likely culprit.
