Oil leak from behind IP.
todds112
Teton Valley, ID
Still chasing down leaks, weeps, and seeps. I've got what appears to be an oil leak (not fuel) from behind and near the front of the IP. I see what looks like a rubber line from the block to the bottom of the IP. Can't tell exactly where it's leaking though. Will I be able to access this line without removing the IP? I think I'm going to have to remove the winch drive shaft to even be able to see well enough up in there. I'm trying to clean the area up with engine degreaser so I can tell better where it might be coming from. Mostly ends up as a thick greasy mess on the winch drive shaft. If it is a rubber line I'm guessing it will be in the same condition as the rubber fuel return line I replaced recently, and a likely culprit.
M35A2-AZ
382
Tonopah, AZ
Yes you can replace the oil line with out removing the IP pump, but it will test your patience!!
That line gets old and cracks and starts leaking.
todds112
Teton Valley, ID
Thx. Also if anyone knows the part number or a supplier, that would be awesome. I'ld rather have a replacement on hand and swap them out than take the old one out, take it to a shop (1.5 hrs away), have a replacement made, then install.
welldigger
15
Benton LA
There are 2 oil lines on the ip. One that goes from the block to the ip gear adapter and one on the bottom that links the gear adapter to the actual injector pump. Replace both just to save yourself some headache down the road.
todds112
Teton Valley, ID
Are they both rubber? I thought it was one continuous line. I need to get up in there and get a better look.
welldigger
15
Benton LA
Yes, they are both rubber flex lines. You should be able to see and replace both from the bottom.
I'm attempting to find the receipt from my hose shop to see if they wrote down the fitting sizes in case gimpy doesn't have any hoses left. Can't remember off hand what they were. I know they are push lock but beyond that I can't remember anything.
