M35 no brake lights
snoplay
copper center Alaska
Katahdin , yes they were aired up, jeepsinker, the reason I replaced it when I would hit the brakes the switch would leak air and pop the wire off but I will recheck the air pressure tonite and the brakes seem to work great
Jeepsinker
445
Dry Creek, Louisiana
Ok, then take the small Allen plug out of the air cylinder end plate and then push the brake pedal. See if it blows brake fluid out. Brake fluid getting in there messes with the brake switches too.
snoplay
the bulbs are good I'm a firm believer in the KISS method , so I will start with is there air , and ck the new part for at that port and the "new"part for faults
THANKS
I love this site!!!
