lxawolf
- 1
- 6
- Sussex, NJ
Working over the last few weeks on a new to me MEP-003a I have gotten a lot done. I have replaced the oil, oil filter, cleaned out the fuel tank, replaced the fuel filters. New battery cables and batteries. Before I did any work on the fuel system I turned the the starter switch to both prime and run positions. Before the work they would click and start out faster then slow as the system comes up to pressure. (As seen in multiple YouTube videos) Now after changing both fuel filters inspecting the strainer, and checking the pump internal filters (aka open the port at the bottom of the fuel pump) the auxiliary fuel source pump clicks but not nearly as fast. Both the primary pump and the return line pump are making no sound or moving any fuel. I took off the fuel line going to the injector pump thinking I might have an air lock but even doing that did not change the outcome.
I took off the rubber gasket on the power supply wire, I am getting 24v at the connection. I also removed and replaced the two rusty bolts with two new bolts holding the pump to the frame thinking that I was not getting proper grounding.
Could I have damaged something just by checking the internal pump filter? I did not use excessive pressure to remove the base, or to put it back on.
Has any one else had a similar experience? Do I need to get a new pump? What can any one recommend trying or doing that I am missing?
Thank you for your help ahead of time!!!
