rsh4364
- 15
- 38
- greensprings ,ohio
Ill be changing out my starter on Saturday for another 24v GR,both are Chinese,The one Im pulling isn't fried,would it be worth it to have it rebuilt? Or just scrap it?
Maybe next time,I was in a hurry to get one so I got one from DB elect.I've got a GM O.E.M direct drive rebuilt (US) unit available if you want to go that way.
I agree 100% with you doghead! I always buy AC DELCO starters & alternators or rebuild the old ones. A correctly rebuilt DELCO starter will outperform any aftermarket starter and it will fit correctly. And you are being good to your flywheel and engine block at the same time. I recommend AC DELCO on all electrical items if you want them to fit properly and last a long time. I have had their batteries to last over ten years in Medium duty trucks. Find a GM dealer that will treat you right on price and it will solve a lot of your problems!Stop buying Chinese.
pm me with a price,last year I had 3 vehicles running,so if one didn't start no big deal.This year its just me and the 1009.And I was just telling a buddy I need to pick up some backup parts..LOL.I've got a GM O.E.M direct drive rebuilt (US) unit available if you want to go that way.
Thanks firefox your post got me thinking,since I live in an apartment building I have no garage or vise and all that goes with it.What I did is surely not wise,but its starting well now.I took a drill bit that just fit into mounting hole,could tell hole was miss aligned,I drilled hole out with cordless drill til drill bit looked straight,took about 4 bit sizes up to accomplish.And to the other guys I know I will be replacing as soon as oil gets cold and thickens up.Here is an idea, but I can't guarantee anything. Take both starters to your workbench.
See if you can flip one over and match up the holes. use a scribe and scribe the new one
thru the holes of the old one. Then you need to see if it is both holes that are too close or
far apart. Or one of the holes is off set and the other lines up. Once you verify this you can
take a round file and modify both holes in the first case, or the one hole in the second case.
Unless there is a huge difference, you should be ok. Just make sure you take your time
withe the initial measurements and marking.
Hope this helps.
You did install the starter brace on the end of your starter didn't you? If not you are asking for more trouble. With the oversize hole this starter will be prone to breaking mounting bolts and or the holes in the block.Thanks firefox your post got me thinking,since I live in an apartment building I have no garage or vise and all that goes with it.What I did is surely not wise,but its starting well now.I took a drill bit that just fit into mounting hole,could tell hole was miss aligned,I drilled hole out with cordless drill til drill bit looked straight,took about 4 bit sizes up to accomplish.And to the other guys I know I will be replacing as soon as oil gets cold and thickens up.
