Got ready to run some errands this morning and bam no start. I have noticed recently that it was getting harder to start. Today it is about 70 degrees and rainy. Not cold by any means.
Symptoms:
Wait light works, on approx 6 seconds
Turns over
white smoke
Checked:
Power at light blue wire at glow plug card: 12 odd volts
Large red wire top of the solenoid on fire wall: 12 odd volts (resistor appears to have been by pasted prior to my purchasing it).
Large orange wire bottom of the solenoid on fire wall: no power with key in the off or on position.
Green glow plug power wire: no power when the wait light is on.
I changed out solenoid on fire wall: same results
Check all fuses: all good
Traced wires: no obvious problems
So now what? Once my ride gets here I am going to get another solenoid, the one I tried was a used one I had sitting around.
My questions are:
How do I tell if the card is bad? Would the card cause these problems?
What else could it be? What am I missing?
Thanks
Symptoms:
Turns over
white smoke
Checked:
My questions are:
Thanks
