rsh4364
- 15
- 38
- greensprings ,ohio
Got some boxes on my door step!New 31 gallon fuel tank,straps,sending unit and harmonic dampner,now if only I had A garage.
Had the same thing happen. Bid on and bought what I thought was a 1008, because the 1028s were going for too much money.Today I found out my supposed m1008 is actually a m1028! No wonder I never got stuck plowing last winter.
Nice. What did that tank run you?Got some boxes on my door step!New 31 gallon fuel tank,straps,sending unit and harmonic dampner,now if only I had A garage.
How do you get your creeper to roll?I can relate to the garage problem - working on gravel in the open is not fun.
You have a creeper? I just put down an old bedsheet or so and crawl/roll underHow do you get your creeper to roll?
I got the tank,sending unit, and tank straps for 204.17$ shipped to my door,tank was 80 bucks.A.Z. had a 20% sale going on plus free shipping..Im planning on a rebuilt IP soon and don't want to run garbage thru it.My current tank keeps plugging my pre-filter with rust,so its time to fix,a plus might be my fuel gauge should work properly.Nice. What did that tank run you?
Sweet deal!I got the tank,sending unit, and tank straps for 204.17$ shipped to my door,tank was 80 bucks.A.Z. had a 20% sale going on plus free shipping..Im planning on a rebuilt IP soon and don't want to run garbage thru it.My current tank keeps plugging my pre-filter with rust,so its time to fix,a plus might be my fuel gauge should work properly.
Lately I've finished installing all new stainless brake lines, new calipers and pads, got the cab corners done, the fuel tank installed, and I got the bed back on. The crane support works exactly like I hoped it would; I've got to drill some holes and get some bolts and it should be good to go. I'll take some pics tomorrow.Today I finished welding the frame for the crane and drilled the mounting holes and bolted it to the truck frame. I put the crane on to see what it will have for reach. Tomorrow, I'll prime and paint the frame and bolt it on for good.
The bed should sit right over it if I made it right.opcorn:
Please post pics of the crane install. I'm looking forward to them.Lately I've finished installing all new stainless brake lines, new calipers and pads, got the cab corners done, the fuel tank installed, and I got the bed back on. The crane support works exactly like I hoped it would; I've got to drill some holes and get some bolts and it should be good to go. I'll take some pics tomorrow.
Something I need in the 1031, I have a great MEP 026C that could live on the home made receiver hitch with cargo shelf. As an auxiliary power unit, for 107 amps of 28 volt DC power to jump start, charge and power. Plus make my 28 volt DC air conditioning system run when not movingHere are some more pics of the crane install.
