cucvrus
10,505
Jonestown Pennsylvania
Put new tires on the work M1008. I put on Good Year Dura-trak E range LT23585R16. This is the 3rd set of these tires and they are the best snow plowing tires I ever used. This truck spends 70% of its life off road. Good tires are important. They last about 20,000 miles and cost about $800. per set of 4. Lat winter was bad on tires in the north east. Lots of ice.
rsh4364
15
greensprings ,ohio
Nice. What did that tank run you?
I can relate to the garage problem - working on gravel in the open is not fun.
I got the tank,sending unit, and tank straps for 204.17$ shipped to my door,tank was 80 bucks.A.Z. had a 20% sale going on plus free shipping..Im planning on a rebuilt IP soon and don't want to run garbage thru it.My current tank keeps plugging my pre-filter with rust,so its time to fix,a plus might be my fuel gauge should work properly.
MarcusOReallyus
820
Virginia
Sweet deal! :beer:
Mine's fine for the present, but if I see rust, I will be replacing that beast! I have a few rusty tank stories behind me. Don't want any more.
Heh. Got a free riding mower due to a neighbor's rusty gas can. Plugged up the mower and he wound up giving it to me. Added an inline filter, replaced the pump, cleaned the carb, and I've been using it for 3 or 4 years now. :D
I_Publius
Prosper, TX
Started working on pulling out the blue carpet that the Sheriff's Dept had installed. Took out the bench seat and the passenger seat to do it. No major rust, which is exciting. Now I have to figure out how to remove all the old adhesive that kept the carpet down. Once it's cleaned well, I think I'm going to install Lizzard Skin or bedline it or both.
Oh...and my GP Controller went out today, so I'm on to using a manual bypass button now and it seems to work fine.
rsh4364
15
greensprings ,ohio
Changed oil and filter today,used Napa 1794 filter and Rotella T6 ,seems quieter and runs smoother,oil pressure warm at idle did drop down to 30lbs. from 50 lbs.Previously ran Rotella 15w-40.Down the road hot oil pressure same,around 60lbs.Didnt get as much done as I wanted,Military son and kids home for short time so busy catching up..Grandkids barely know me..
86m1028
17
Murphy TEXAS
I thought I would do a little work on one of mine today.
I reached down in the side of the frt left fender & grabbed ahold of this guy.
I guess he's protecting my wiring from field mice.
Evil Dr. Porkchop
352
Colchester, VT
Today I finished welding the frame for the crane and drilled the mounting holes and bolted it to the truck frame. I put the crane on to see what it will have for reach. Tomorrow, I'll prime and paint the frame and bolt it on for good.
The bed should sit right over it if I made it right.:popcorn:
Lately I've finished installing all new stainless brake lines, new calipers and pads, got the cab corners done, the fuel tank installed, and I got the bed back on. The crane support works exactly like I hoped it would; I've got to drill some holes and get some bolts and it should be good to go. I'll take some pics tomorrow.
86m1028
17
Murphy TEXAS
Please post pics of the crane install. I'm looking forward to them.
1,827
Whilst at the GA Rally I swapped beds with Speddmon and ended up with the older SECM bed on my truck. I put these boxes in the side. I've done these before with Kobalt boxes. These are the older design drawers with metal slides instead of bearings. I found the bearing slide drawers difficult to keep closed if the truck was not level.
Also wanted to show the disposition of the steel topper off the M1008 bed.
Keith_J
1,328
Schertz TX
Here are some more pics of the crane install.
Something I need in the 1031, I have a great MEP 026C that could live on the home made receiver hitch with cargo shelf. As an auxiliary power unit, for 107 amps of 28 volt DC power to jump start, charge and power. Plus make my 28 volt DC air conditioning system run when not moving ;)
