- 12,195
- 319
- 0
- gainesville, ga.
Just a note to all you m1070 owners, even with the switch turned off there still is a current draw, the -10 for these trucks states that due to the current drew, the battery WILL drain down on trucks that are not used regularly, on some of the m1070s, a master power cut off for both 12v and 24v has been installed to address the current drew issue, With that being said,I would install a battery cutoff switch in the ground on the HETs that do not have the cutoff to prevent a low battery/starting issue with trucks that do not see a lot of use,
