- 1,450
- 119
- 63
- Gray, GA
I finished the coolant filter install. I used the bottom two bolts for the transmission filter head to mount the bracket. Also picked up some Penray coolant additive and test strips from Truck Pro to get my coolant in check. I decided to do everything manually instead of using an SCA filter so the coolant filter is just a standard filter. Will be installing a block heater tomorrow night to finish up my work on the cooling system.
Also ran the starter cables through some 1" rubber hose to keep them from grounding to the block. I had noticed the bad routing when going over the truck when I first bought it...then read the horror stories on here. Shouldn't have to worry about it now. Got switch, extra cable and solder ends for the battery disconnect switch. Will probably get to that next weekend.
![IMG_20141105_154248_564.jpg IMG_20141105_154248_564.jpg](https://www.steelsoldiers.com/data/attachments/358/358816-e735ae539f5ca7a13f6015e0f6ff9c4c.jpg)
![IMG_20141105_154141_612.jpg IMG_20141105_154141_612.jpg](https://www.steelsoldiers.com/data/attachments/358/358813-b41916ec13bae896d94977a691100476.jpg)
![IMG_20141105_154218_594.jpg IMG_20141105_154218_594.jpg](https://www.steelsoldiers.com/data/attachments/358/358814-f123d3e4cf04fa80f078c8119ee694d5.jpg)
![IMG_20141105_154156_401.jpg IMG_20141105_154156_401.jpg](https://www.steelsoldiers.com/data/attachments/358/358815-11cc5724f93db0b9cbf36f585fa2232f.jpg)
