Sistersoldia
- 0
- 0
- Taconic Hills NY
I have a 1986 m1008 with what looks to be the original starter relay (i know... i know...) and this morning, after cranking for longer than normal ( i could tell the battery was starting to wear down - its 9 degrees here)
the starter continued to crank after releasing the key. Thanks to you guys i recognized the doom that had befallen me, and i reached under the dash and quickly removed the starter relay.
To my surprise, the starter continued cranking !!! I popped the hood and ran around frantically grabbing battery connections as the starter ground on slower and slower - and in a feat of superhuman strength i managed to pull off the front positive connection and everything stopped.
I wanted to see just how screwed i was and if I had fried my starter, so i re-installed the starter relay & the battery terminal and hit the key again...same result: The starter ran away- i pulled the relay..still cranking until i removed the front positive terminal.
My question is: What the Heck ? Shouldnt the removal of the starter relay stop everything dead ? or is this possibly a stuck solenoid or something on the starter itself that is continuing to power it without the relay?
The starter apparently isnt completely fried, but im hesitant to just throw a new relay in and expect my problems to be over with. Any guidance would be appreciated - im a bit of a mechanical novice but not a compleat moron so ill try to keep up. Thanks to all !
