Are the M1009 differential covers special military parts?
TexAndy
15
Bee County, Texas
Just went to replace my rear differential cover and the holes do not line up with the replacement I got at Oreilly's.
I told the clerk it was for a diesel 4WD 85 blazer.
Did the military 1009s use a different axle housing from the civilian blazers?
The replacement is a 10 bolt cover... the holes just don't line up and the replacement is slightly too small, to boot.
Keith_J
1,317
Schertz TX
How far off are the holes? That is weird. Guess they use RTV and no gasket. But you could make a tracing and take it back to them.
Keith_J
1,317
Schertz TX
Must be wrong part. Not out of the standard. I've gotten wrong parts several times. Now Chinese castings? All out of spec. I've had to grind brake parts like wheel cylinders and rotors because the casting surface was way too large. Guess iron is cheap in China.
KansasBobcat
San Antonio, TX
Got the exact fit gasket at O'Reillys in Castle Hills (San Antonio) Told them 10 bolt 1984 K5 Blazer. Used RTV on installation. No leaks. Hope to see you at next SA meet. Bob
TexAndy
15
Bee County, Texas
Is your original cover repairable?
Maybe. I'm afraid to try, because the only way to secure it to hammer it back out is against the flange. More likely to bend other parts of the flange than to fix the little piece that's keeping it from sealing.
Going to take it back to OR's with me and see if we can find the correct replacement part.
Recovry4x4
LLM/Member 785
1,807
GA Mountains
Are you replacing the front or rear? Both are 10 bolts and have different covers. Pics help.
cpf240
Free in Northern Idaho
Is the part # different for an '84? These trucks are all built from '84 parts... if the factory made a change between '84 and the other years in the civy line, the part may not fit the CUCV then.
