We're not talking about those engines.I know tons of guys driving on mixture in cummins and power strokes with zero issue
I'm not sure anywhere in this conversation did I ever say I had a Cucv. Even though I don't have a Cucv, does not prove the theory that you can't successfully run a diesel on wmo or any other waste fuel. I'm wondering when the engineers were designing the multi engine did they think, gee lets design this to run in waste motor oil or ATF or veggie oil. I guarantee they never designed it to do it. But it sure does run. I'm telling you, I know for a fact people have been doing it for years and years with zero issues.
Oh so the Detroit diesel is an inferior engine then?We're not talking about those engines.
Not owning one does tell me(and anyone else) that your advise is not first hand based on the truck in question.I'm not sure anywhere in this conversation did I ever say I had a Cucv. Even though I don't have a Cucv, does not prove the theory that you can't successfully run a diesel on wmo or any other waste fuel. I'm wondering when the engineers were designing the multi engine did they think, gee lets design this to run in waste motor oil or ATF or veggie oil. I guarantee they never designed it to do it. But it sure does run. I'm telling you, I know for a fact people have been doing it for years and years with zero issues.
Well my mog is a gas engine so no I don't. If it was diesel I sure would.Do you run your mog on waste oil?
No, I never said inferior. The GM diesel is not the same, different pumps, indirect injection and more.
Sorry mr engineer. I guess it's better for my online experience on steel soldiers if I just bow down to the holy ones on here and not disagree. Heaven forbid anyone have different outcome he contradicts you.Not owning one does tell me(and anyone else) that your advise is not first hand based on the truck in question.
I'll bow out now and wait for my account to be locked out.Your attitude sucks, so leave it off the site.
Yep. It's on steel soldiers so it must be true.That is the problem, I heard from the grocer who was told by the paperboy that he read it on the interweb that the diesel engines were running fine on zebra sweat in Antarctica.
Must be true.
This forum is much better when people report their personal findings, and not just regurgitate hearsay as if it was gospel.
I'm with youStop arguing in the forums.
OK. Thanks for the infoA few quarts of clean used gasoline motor oil per fillup won't hurt once and a while. But 50/50 waste diesel oil is bad for the pump.
the clearances in the DB2 are just as precise as in the multifuel Ambac units. Otherwise neither could pressurize diesel to 2000+ psi. Used motor oil is far from a good fuel in any Diesel engine as it doesn't spray well so it burns poorly. Waste diesel oil has more ash forming chemicals so it cokes chambers and valves. Diesel has ZERO ash. Gasoline engine oils have been reducing ash forming chemicals so they are better. Two stroke oils are also ash free.
