ballencd
- 100
- 43
- Columbus, NC
When I converted my bobbed M35 to a dump I installed a 12V hoist pump (on one battery) since I could not find a 24V pump at the time. (the pump was included in the kit) I have had pretty good luck with it but when I am busy moving dirt I run the one battery down and have started charging the battery while I am loading with a 120V battery charger. This works OK but only marginally....the pump takes about 42-45 seconds to dump and then almost that to lower the bed after the dump and it is a real pain to plug in the charger after every load. I forgot once and ran over the charger also allowing me to get a new charger! : (
Somewhere in the dump conversion threads I read while I was building the dump I found a thread where the user said something like "I installed a 12V pump on my 24V truck and it has run fine for 7 years" or something to that effect. At the time I read it I assumed he had connected the pump to one battery like I had but have been thinking if that is really what he did??? My question is: "Does anyone remember this thread or know what would happen if I connected the 12V pump across the 24V batteries?" I am thinking back to the 60's when I converted a VW from 6V to 12V and used the 6V starter with no problems. The starter ran faster but didn't burn up.
