- 34,012
- 1,807
- GA Mountains
I agree 100% Sir!It was a rhetorical question. Was just making a statement how a vice is safer as was mentioned in the thread. Either way can cause damage in reality, if one isn't careful.
Just a question. Did you put the snap rings on the caps that went to the differential yoke? On the M1009 that is what holds the u-joint centered in the differential yoke.
Am I the only one who used the TM for this repair?Rear universal joint (7) uses 2 bearing rings (5). Front universal joint (
uses 4 bearing rings (2).
