scottladdy
- 10
- 18
- CT
How much did that set you back?Also picked up a amber lightbar as well
NICE! Looks like it is coming along nicely! You going to be at haspin this year?Hey JD, It's going to look good when you're done. I"m still plugging away at the M884. Looks a little different than it did at Haspin 2 years ago.
MyIt' amazing how much rust that stupid rubber floor mat with the insulation causes, the floors rust from the inside out , I didn't listen to my own advice when I got my 1008 and I left the mat in, best thing to do is go with the made floor pieces as they have all the proper bends and fit great , I weld everything with plug and butt welds then use a zinc primer and paint , then to finish the truck gets Krown oil spray from top to bottom and then some ,
I'm not sure if they do or not.. But after working with the floor pans, I feel a tad more confident in my sheet metal skills, so I am trying my hand at making my own.. This is the first time I've ever worked with sheet metal, and I've only (very) recently started using a mig welder (takes some getting used to) I'm used to a stick welder and doing heavy welding lolQuestion. Don't they make that center part of the floor?
