Drock
- 12
- 0
- Eatonton GA
As of today still no brass/copper radiator from autozone,and we are up to 5 alum rads.shipped.Ready to explore other options!I received 1 brass copper radiator which was a mess to my home,and so far 2 alum. rads with plastic end tanks delivered to autozone even though they called and ordered the brass copper rads.Im not happy,all boxes say b850/cu850 on them.
If your interested in an aluminum rad. I'll be ordering one from these guy's when the time comes..............http://www.buyaradiator.com/i-s-2098aa.htmlAs of today still no brass/copper radiator from autozone,and we are up to 5 alum rads.shipped.Ready to explore other options!
I just put ah bottle of water wetter in yesterday, I haven't driven it yet to see, but it should drop the temp ah few degree's.....http://shop.advanceautoparts.com/p/...4/7120012-P?searchTerm=redline&zoneAssigned=1Once fully warmed up my sunpro holds at 190. Idle/cruising/summer/winter all the same. Takes a heck of a lot longer to get there in the winter though.
You lost me? do you mean a 180 thermostat rather the 195?180 is an aftermarket fix for advoiding a blown head. You need it with the heat the th400 put into the radiator
I suppose you could try? The only problem I would foresee would be do to the fact that it is pretty thin and made of cast aluminum. So it could crack or simply not have enough thickness to get any threads on. But if it did mess up you could have one on your doorstep for around $50.00 off ebay.i was wondering if i could drill and tap the crossover that already there??
