Near Greensboro, NC Airport, WAS stuck 5 ton pretty good!
mikey
40
Lake Como, PA
You can probably get out of there if you deflate to 30psi. Looks like you're at like 80psi.
Also, your sig says you have a wrecker. You can't get it out with the M936A2?
Mikey
Scar59
42
Mt. Eden, KY
Mikey
Yep, time to get the wrecker out. The rear winch with a snatch block will pull it right out of there, dont forget the mud spades, ground looks saturated/slick.
Take more pictures. Be safe.
JC
PowerstrokeNC
Greensboro, NC
Thanks to everybody who called as well as suggestions. I just sold the wrecker a few weeks back. So the rule applies" just when you sell your wrecker you will need it the most"
I really appreciate the comraderie on this site! I had SS members calling from far away as SC willing to drive up to help. Thank you all.
I landed getting out with a 70 ton wrecker hired locally, they were close by so not too bad...
Glad to be out!
doghead
4 Star General /Moderator
1,191
fixed title
526
Winston-Salem, NC
I just can't believe how much the frame twists, plus really surprised the front suspension has that much flex. Was Parker not able to pull you out with his truck, or you just needed it out sooner than he could get there?
